DEVELOPERS FORUM - Deleting the latest revision should revert back the changes
sherenegladysj - Friday, December 4, 2009 12:53 AM:
Hello all,
I have a Released Part as Revision "A" by undergoing through an ECO. Again I revised the Part to "B". I want to delete the "B" Revision Part which is in Preliminary state. Aras did not allow me to delete because it is referred in ECO. I had to delete all the relationships before deleting the Part. Now, "A" revision Part is in "In Change" state. I want that to be reverted back to previous state. The state of the "A" revision Part should be "Released". In ECO & other BOM structure "A" REvision Part should be referred. How can I achieve this?
If the Part has Child, in that condition also it should point to the latest exsisting revision.
Part BOM Relationship Type Item Behavior is "Float" and Part Lifecycle Released state Item Behavior is "Null"
Thanks in advance,
Sherene
