DEVELOPERS FORUM - Handle for the Innovator object for an open form?
RonCK - Monday, February 1, 2010 1:24 PM:
I'm trying to edit a form OnLoad method to do some form reconfiguration based on whether the user is part of a group identity.  Looking at the API, I saw "innovator.getUserID()", which looks like it may return something that I can use to determine whether to make changes or not.  This method fails when included in my code as is.  I assume this is because the innovator is not the correct name for the active object.  Is there a way to grab that handle?
thanks,
RonCK
RonCK - Tuesday, February 2, 2010 9:12 AM:
I found it in case anyone else was missing it.
In Javascript use:
innovator = document.thisItem.getInnovator();
Then the innovator methods can be called using innovator.
Best regards,
RonCK
