Lars E Carlsson - Wednesday, February 9, 2011 3:09 AM:
Normal 0 21 false false false SV X-NONE X-NONE MicrosoftInternetExplorer4
Ronan - Wednesday, February 9, 2011 9:25 AM:
Under Windows XP, Innovator requires a XML update. It should appear as an ActiveX component update prompt.
There is documentation helping you to setup Innovator clients: in the Downloads section, have a look at Aras Innovator 9.2 - Internet Explorer Client Machine Configuration.pdf
dnohr - Friday, February 11, 2011 12:43 PM:
I've having the same issue when trying to open the client direct from my windows 2008 server.
I am propted to install MSXML 4.0 SP3 but after still clicking Install I get the same message:
dnohr - Friday, February 11, 2011 3:09 PM:
I seem to have fixed the issue by installing MSXML 4.0 SP3 directly, rather than clicking install from the popup.
Lars E Carlsson - Saturday, February 12, 2011 3:26 PM:
Hi and thanks!
I installed the MSXML 4.0 SP3 directly and now I get the login window.
But when I enter admin/innovator I get : Login failed for user "innovator"
I searched and read the forum back and forth but have not figured out why it do not work.
Anyone that knows this one aswell?
All the best!
Lars
Ronan - Monday, February 14, 2011 9:26 AM:
This one is a common error occuring when you haven't properly set up the access right at the database level.
Connect to your SQLServer instance, then execute the following lines on your Innovator database:
sp_change_users_login 'Update_One','innovator','innovator'
sp_grantdbaccess 'innovator','innovator'
sp_addrolemember 'db_owner','innovator'
Lars E Carlsson - Tuesday, February 15, 2011 4:35 AM:
Normal 0 21 false false false SV X-NONE X-NONE MicrosoftInternetExplorer4Hi and thanks for trying to help!
I am sorry but I am very new to database and only want to try Aras since I am very used to PLM.
I think I executed those lines but get the following
Msg 102, Level 15, State 1, Line 2
Incorrect syntax near 'sp_grantdbaccess'.
Any idea?
All the best!
Lars
Ronan - Tuesday, February 15, 2011 1:09 PM:
Looking at your error message it doesn't look like you pasted this at the correct place...
You need to connect to your DB using the MSSQL Management Studio, then right-click on your DB, click New Query, then execute each line. These are T-SQL statements, they cannot be executed from an Aras method.
Is this what you did?
