SUPPORT Q&A - How to start Aras?
Aldihu - Tuesday, January 5, 2010 3:27 PM:
Hi.
A friend of mine installed aras on my computer for me. I know that the program is running but I don´t know to log-in! (Please don´t laugh)
 In the manual I have red that I need a server name and an innovator_web_alias. Where can I get this information from?
Greetings Marc
dstephen - Wednesday, January 6, 2010 6:33 PM:
Marc,
I'm assuming the install went cleanly and exactly per the documentation.  So, that should mean that you have IIS up and running on your machine.  If you open IE and try  localhost/innovatorserver  that should bring up the login screen. Then you should be able to login as user = admin and password = innovator.
If you don't get the login popup from the url above, go to Control Panel > Administrative Tools > Internet Information Services (IIS) and when you have the IIS client open you should see your machine on the left side, navigate down to Web Sites > Default Web Site and you should see something that looks like Innovator.  Use that as a replacement for innovatorserver in the url path above and give it a try.
Good Luck,
Don
