DEVELOPERS FORUM - Mulitlevel ManufPart BOM Report error
jeromepereira - Sunday, July 25, 2010 8:31 PM:
v9.1 Demo database has a multilevel bom with mfr part number report.  We found if you put the same item on a bom twice (example of this would be for a qty=0 "Nonstuff" component option on a circuit board) the report does not give you both lines...rather only one line shows up on the report...anyone else seen this?....not sure if this report is used by others outside of the demo database...but thought I would report our observations in case it needs fixing by a capable person (I am not skilled enough to know how to make/change/fix reports at this point)
