Installing Reporting Services
Reporting Services is a component of Microsoft SQL server 2019. Click on this link to download Reporting Services separately: https://www.microsoft.com/en-us/download/details.aspx?id=100122. The Microsoft Download page appears.
Use the following procedure to download Microsoft SQL Server 2019 Reporting Services and install it:
Scroll down to Microsoft SQL Server 2019 Reporting Services.
Figure 1.
Click Download. The dialog box shown in Figure 2 appears.
Figure 2.
Click Run. A security scan is run. When that is successfully completed The dialog box shown in Figure 3 appears.
Figure 3.
Click Install Reporting Services. The dialog box shown in Figure 4 appears.
Figure 4.
Select the Enter the product key button and type the product key in the appropriate field.
Click Next. The Review the license terms dialog appears.
Figure 5.
Select I accept the license terms and click Next. The Install Database Engine dialog appears.
Figure 6.
Click Next. The Specify an install location dialog appears.
Figure 7.
Use the default location shown here or click Browse to select a different install location.
Click Install. When the set-up procedure is complete, the dialog box shown in Figure 8 appears.
Figure 8.
Click Configure report server. The Report Server Configuration Manager dialog appears.
Figure 9.
Click Find to select a different server name.
Click the down arrow in the Report Server Instance field to select a different Report Server Instance.
Click Connect to connect to the appropriate server. The dialog box shown in Figure 10 appears.
Figure 10.
Click Start. You can modify or define settings for the Report Server. Click Stop to stop the Report Server.
In addition to selecting the Reporting Services option, you can select Analysis Services that provides graphing and charting functionality.
