Getting Additional xProperty Information
Every xProperty has a complex structure that includes the following information:
A value
A definition
Private permission
Flags
Note: Due to performance considerations, the default server only returns the xProperty value in the AML response.
You can extend the syntax of the @select attribute to get additional information about the xProperties defined for an item by using the following attributes:
$value
@permission_id
@explicit
@defined_as
The following example gets all Parts contained in the database. It includes the item_number and all the defined xProperties for each returned item in the response:
<AML>
<Item type=Part" action="get" select="item_number, xp-*(@defined_as)"></Item>
</AML>
<Result>
<Item type="Part" typeId="3B135425…" id="0FA8ED…">
<item_number>999-888</item_number>
<xp-length defined_as="class" is_null="0"/>
</Item>
<Item type="Part" typeId="4B135425…" id="1FA8ED…">
<item_number>999-777</item_number>
<xp-width defined_as="class|explicit" is_null="0"/>
<xp-height defined_as="explicit" is_null="0"/>
</Item>
</Result>
The following example gets additional information about the defined xProperty (permission_id, explicit):
<Item type="Part" action="get" select="item_number, xp-cost($value, @permission_id, @explicit), xp-length($value, @permission_id, @explicit)">
</Item>
<Result>
<xp-cost explicit="1">10</xp-cost>
<xp-length permission_id="123..." explicit="0" />10<xp-length>
</Item>
</Result>
The following example gets additional information about the defined xProperty (is_defined):
select="item_number, xp-*($value, @defined_as)">
</Item>
<Result>
<xp-height defined_as="class|explicit"/>10<xp-height>
<xp-cost defined_as="explicit">10</xp-cost>
<xp-length defined_as="class"/>10<xp-length>
</Item>
</Result>
