At least two places in our system we experience zombie tabs, tabs that after an error message are impossible to close.
I can now reproduce the issue: We have a custom "Delivery Risks" tab on parts. If I add a new risk and open it, the UI thinks the object is in a dirty state. Just opening it and closing it again, I get a popup with "Changes have not been saved. What do you want to do?". If I select "save" here, I get the error
at T0 (factory.ts:152:8)
at Object.execute (factory.ts:169:24)
at onUnlockCommand (include.aspx?classes=tearoffWindow:915:36)
at async eval (eval at x0 (factory.ts:53:9), <anonymous>:30:10)
at async T0 (factory.ts:140:10)
I can avoid creating a zombie tab by clicking "Edit" and "Save" manually in the form. Even though there are no changes, that apparently syncs the state properly.
Requesting the object with AML studio, newly created items in potential zombie state look exactly like ones which have been edited and saved, so the problem isn't in the database end. Fully logging out and logging in again also clears potential zombie state, but merely closing the Part does not. So it's some kind of Item cache in the frontend which thinks the Risk object is dirty - or possibly it's the Form Item which is dirty.
This is Aras 31 by the way.
