Hi community,
As a test, I created a new itemtype called "Test". I defined a property on "Test, called "nested", which is of type=Item and DataSource=Form.
Then on the Form definition for "Test" I added a field called "Nested Form", with its Field Type=Nested Form and Data Source=nested. I added an HTML field instead and just changed its Field TYpe "nested"
On creating new form it won't give me the result also i couldn't see the field is searchable .
any suggestions ??????
thanks in advance.
On the form definition for "Test" try adding a property to the form with field type="item" and data source="nested". Additionally, add another property with field type="HTML" and data source="nested".
Use the item property to select the form you would like displayed in the html field.
