If you've ever wanted to change the theme of the Aras Method Editor, this is the post for you! With the following quick and easy tweak, you can change the colors and fonts used to display method code in the editor.
Six different themes in the Aras Method Editor: Textmate (default), Ambiance, GitHub, Idle Fingers, XCode, and Monokai.
Getting Started
For this customization we will be modifying a code tree file, so be sure to backup your code tree before making any changes to your Aras Innovator configuration. Backing up a code tree is as simple as zipping up the Innovator folder and saving it to another location. This will ensure that you can completely revert any changes you may make.
1. Choose the Theme
First, you need to select the theme that you want to use in the method editor. All 32 themes are defined in Innovator\Client\scripts\CodeEditor\javascript\src-min-noconflict\
and follow the theme-theme_name.js
naming convention. For example, the Crimson Editor theme is defined in theme-crimson_editor.js
If you want to preview the themes before choosing one to use in Aras, you can use this theme previewer for the Ace code editor.
2. Update the Editor
To change the theme of the method editor, we need to update Innovator\Client\scripts\CodeEditor\MethodEditor.html
. As shown in the code snippet below, you will need to replace "textmate" with the name of your chosen theme.
Note: If your theme name includes spaces, replace the spaces with underscores. Ex: "Tomorrow Night Bright" becomes "tomorrow_night_bright".
Bonus: You can also set the font size and font family in the above editor.setOptions()
call.
3. Refresh the Browser
Once you have saved your modification to MethodEditor.html
, clear your browser cache and open up a Method Editor window. The editor now loads with your new theme applied.
My personal favorite theme, "Idle Fingers".
A Few Notes...
- This modification is suggested for development/non-production environments only.
- Modifying other parts of
MethodEditor.html
or other files inInnovator\Client\scripts\CodeEditor
may result in unexpected results or negatively affect functionality. - This modification may need to be reapplied after a major version upgrade of Aras Innovator.
