Just Released - Aras Scalability Testing: 125,000 Concurrent Users
The results of the largest testing conducted to date in the enterprise PLM industry are in. Testing validates that Aras Innovator 10 can handle very high numbers of concurrent users – 125,000+ – when running on standard server configurations.
The independent testing was completed by Logic 20/20 for the scalability of Aras Innovator 10 running on Microsoft SQL Server 2012 Enterprise Edition on HP ProLiant servers with the HP ioDrive2 Duo IO accelerator technology from Fusion-io. Results show optimal performance and resource utilization for 500,000 named users with 125,000 concurrent users with real-world scenarios and data structures to simulate actual usage.
Download the report for test details, scenarios and analysis.
Logic 20/20's Performance Conclusions
  • Aras Innovator 10 and SQL Server 2012 Enterprise Edition running on standard HP server configurations showed strong performance and excellent resource utilization across all tests.
  • During testing average CPU utilization was consistently below 25 percent and total percentage of CPU utilization never exceeded 30 percent.
  • The average response times were fast across the different concurrent user loads tested from 25,000 to 125,000.
  • As expected in an online transaction processing (OLTP) workload like Aras Innovator 10, the greatest constraint was in the I/O subsystem's ability to read and write to disk.
  • The benchmark testing results validate that Aras Innovator 10 running on SQL Server 2012 Enterprise Edition scales nearly linearly with hardware upgrades and is architected for very high numbers of concurrent users.
  • The performance of Aras Innovator 10 is not constrained by its architecture. The design puts the burden of work on the hardware, so it can be scaled-up and scaled-out with server hardware.
Get the full report!
