Limiting Items View Based on Project Context
Sometimes, you just want to see items like Parts and Documents that are relevant to a specific project you are working on. Even if you have access to other projects, you just want to see the ones you will work on this afternoon.
The solution shown in this video provides this feature but make sure to understand that it is not a permission-related solution. There is no added security it is just filtering the views based on the project you selected to be active for yourself.
The code should be soon published on our Github organisation page. You can already check out the actual projects published. I will update this post when this code will be added. If patience is not your best quality, ask me for the code by commenting this post!
https://github.com/ArasLabs
