If you weren’t able to attend our most recent monthly Aras Innovator Demo Series you’re in luck! We recorded the session so you can watch it at your own convenience.
The December Demo Series was a bit different than our typical Demo Series webinars. To wrap up 2016 we hosted a special 90-minute demo series event. Joined by a few of our great partners we demonstrated innovative modeling examples using the Aras Innovator platform.
Didn't get a chance to attend the demo series? No problem! We know how busy December can be so we recorded the whole webinar. Get the video
The Line Up:
A new way to visualize Aras data: A Graph Viewer
Minerva
Developed for Airbus, this Graph extension on top of Aras Innovator allows end users to visualize data as oriented graphs for a better understanding of the data and the relationships between them. Easy and friendly interface, filtering capabilities, and discover mode.
How to use Innovator core functionality and custom API's to display items and their various manifestations to users
Aras
This demo will help customers who wishes to implement a complete system for managing their entire product information management process. Customers who has the need to classify their information based on Model, Series and Line can benefit from this solution approach. The solution is designed to be scalable and maintainable with minimal code modifications.
Add and Remove Affected Items on an In Work Change
Razorleaf
Sometimes a change process requires additional affected items to completely implement the change. Depending on the state of the change, it may not be possible to add additional affected items, so a second change is started. This solution will allow additional affected items to be added to the change and have all of the same business rules applied as if it were on the change from the start. The solution also works for removing affected items.
Dynamic Workflow Assignments
EBD Advisors
When a customer needed the ability to change workflow assignments after initialization of the workflow process we created a custom solution to manage the business process. We modeled a custom workflow process behaviors so that changes to the Team assigned to the Controlled Item would be reflected in future assignments within that specific workflow process.
BOM Editor
AESSiS
Making changes to multiple levels of a product structure can be time consuming. To increase efficiency, we created a BOM Editor that gives you the ability to manipulate and edit all levels of a multi-level BOM simultaneously in a single interface.
For more information and upcoming demos visit www.aras.com/demoseries
