hii
i have one item type QDM having field which datatype is date and pattern is shortdate
i select 4/28/2017 date where 4 is month , 28 is day
and save item
then i open sql server
and open data for QDM , the date selected is stored as 4/27/2017 (one day less than i selected)
it is only problem with short date if i change pattern to short datetime then date stored in sql is correctly
please help me
Hi rrt,
Can you confirm the time zone of the client, and whether there is a corporate time zone set in the database? I believe the discrepancy you are seeing is related to how the Aras client converts the client machine date/time to UTC when it is stored in the database.
Eli Donahue
Hi rrt,
Eli Donahue
