tigrao - Tuesday, November 30, 2010 12:05 PM:
How could I to insert a new attribute in ItemType "USER"??? Please!!
Brian - Wednesday, December 1, 2010 6:58 AM:
Hi Tigrao,
User is an Item type like mos things in Innovator.
You can edit it just like you can edit anything else and add a new Property.
What you have to be careful of is that it is a core Item type so you need to make sure that you don't upset anything when you edit it.
Go to Item Type under Admin in the Table Of Contents Menu.
Search for User.
Right click and "Edit".
If you get the error "You don't have sufficient permissions to lock this item" then you will need to log in as either Administrator (if not already) or Super User (ie "root") if the administrator does not have permission to edit the Item Type
Once you have added the new property you will probably want to put it on the user form.
Go to "Forms" under the TOC Administrator and seach for "User".
Edit the form but again be very careful that you don't disrupt something that needs to be there for other functions.
Hope this helps.
tigrao - Wednesday, December 1, 2010 7:40 AM:
Hi Brian, thank you very much!!
with admin/innovator I have not permission to this, but with root/innovator I got what I wanted.
thank you.
