DEVELOPERS FORUM - Problem at the time of Changing USER schema
vishal_trivedi - Friday, December 10, 2010 7:11 AM:
Case:
Created an Item type called 'Department'.
-- Created list 'Department List'
-- Write 3 methods to add,update and delete the items of Department into Department List.
-- Assigned this list at form of 'User'.
Problem:
At the time of performing above changes, it is allowing to do that for our default DB 'InnovatorSolutions'.
-- But it is showing error if I am performing this changes in my DB.
Error:
-- Select permission denied on column 'Department' of object 'USER'.
-- Vishal
