Ronan - Wednesday, January 5, 2011 9:36 AM:
I've just installed 9.2.0sp3 in a Windows Server 2008 SP2 virtual machine. Everything works as expected on client side (in the host, outside of the VM), but inside the VM it is impossible to access to Innovator. Here is what happens when I open http://localhost/Inno923 from inside the VM:
- As expected, redirect to http://localhost/Inno923/Client (fine)
- As expected, a second (login) window begins to pop (fine)
- Then the login windows remains in a "connecting" state
- After ~10 seconds the first window shows a warning saying "
Message: Just opened IE window was not found. Line: 40. Char: 7. Code: 0. URI: localhost/.../"
And here is the aforementioned line 40:var thisBrowserOrTab = ieClient.Start();
Again, Innovator works on the host machine (the physical machine), but this problem happens when trying to login from _inside_ the VM. Any idea?
Both machines use IE8, sdns was run, IE client machine config was done (IE protected mode disabled, Innovator in Trusted sites, scripts options checked, no Compatibility mode)
Host (physical) machine: Windows XP SP3 x86
Guest (virtual) machine: Windows 2008 R1 SP2 x86
Thanks for your help!
Ronan - Monday, January 10, 2011 5:23 PM:
Workaround from Aras Support: "Reenter the Aras Innovator URL into second window that pops up after receiving the error. By entering the URL into the second window you should be able to successfully load the login window."
This is needed because WS2008 isn't officially supported as a client. They filed a ticket however, and the issue might be fixed in a future release of Innovator.
authentic - Monday, August 15, 2011 3:41 AM:
nTiger1: Nike Shoes advertisements can be found almost anywhere. In all corners of the world, you can find big banners with the words NIKE on them. The Nike Free Run is one of the shoes that Nike is really proud of, making them the highlight of their advertisements and commercials. At the same time, Nike advertisements are also found in all top sports meet, sponsoring the professional athletes on the embark for glory and outbreak. On our Nike Shoes Australia, you will find the many shoes you have seen on the ads and TV commercials. Our Nike Shoes Online will not disappoint you with our huge veriety of Nike footwear.
My dear friends, so happy that you can see our store various and good performance Nike Shoes. As we all know that, as the no pressure wear feel spread over the world. We all persue the easy breath and lightweight shoes to realease our feet. Nike Shoes made it. Nike Free Shoes is come here to safe you. The barefoot design can let you enjoy amazing feel. Apart of that Nike Free Run 2 also can be yoru choice. If you wanan find a pair of awsome look shoes with various colors, Nike Air Max in good condition for your reference. Nike Air Max 2011 Australia with Nike Air Max unit resilient to absorb the impact gurantee your support. Nike Zoom Kobe VI in low cut design gurantee your free motion on court and improve your workout hot sale online now. What are you waiting? The chance to order the cheap and good performance Nike Shoes on your eye sight now. Just catch it! Fast and free shipping worldwide!
