brueegg - Friday, January 7, 2011 7:20 AM:
I'm trying to open a new form from an action. This is a general action with now relationship to an item. So you can call this action all the time.
What I want to do is, put some default values to the user item. Because a standard user doesn't see his own item, I wanted to call a seperate form to manage his values.
I'm able to load the form an save some values to the user item. But I'm not able to have some text field with a search form attached.
If I press the ... button, an script error appears. I also tried to call the user form, but there is the same problem.
Does anybody have an advice?
Thanks a lot
Ronan - Friday, January 7, 2011 8:41 AM:
Have you tried debugging it in IE or in Visual Studio?
What is at the mention line "354" of this javascript method?
JensRollenmueller - Monday, January 10, 2011 2:40 PM:
I think there is an other way quite simple to resolve your problem without programming.
- Just get the Form (user form) with all the information.
- Do an save as for this form "usersettingsform"
- modify your form (delete fields, set fields to enabled ...)
- now attach the new form "usersettingsform" to the item type "user" (within the views tab)
AND use a created identity of the current user (create your own one).
Thats all.
The normal ItemType "user" could not be modified by the admin user. I don't know how, but I think there is an easy way to attach the new form for the item type user,
Regards Jens
brueegg - Friday, January 7, 2011 8:56 AM:
Yes I did, but I'm not the master programmer.
The error ist:
system$5D27800922664C9EBD83F58724CD99BD$OnF2Down(event.srcElement.parentNode)
the whole error code is:
<input type="image" id="5D27800922664C9EBD83F58724CD99BD_img" align="absmiddle" height="12" width="16" border="0" unselectable="on" src="../images/Icons/other/12x16_elipsis.gif" style="cursor:hand;" onclick = "var curInputEl = document.getElementById('5D27800922664C9EBD83F58724CD99BD_input');
if (curInputEl != document.activeElement && !curInputEl.disabled) curInputEl.focus(); system$5D27800922664C9EBD83F58724CD99BD$OnF2Down(event.srcElement.parentNode)"/>
I don't know what is missing.
brueegg - Tuesday, January 11, 2011 2:07 AM:
Hi Jens
Thanks for the advice.
I thought about this way too and I also tried it, but the problem is, that the user is only allowed to see and modify his own user. I probably can filter these items with a program and ask the current user before locking.
Does anybody has another idea?
