DEVELOPERS FORUM - How to get the object not to be unlocked after its creation with IOM API just as UI NEW Cammand?
lin227 - Friday, January 7, 2011 11:32 PM:
If I use IOM API ITEM.newItem("Document", "Add") method to create an item instance, by default it will be unlocked. If you lock,edit and unlock it, it will create a new generation.
I just want to create it without being unlocked, just as UI NEW cammand. Then untill I finish other works, I will first unlock it. How can I get this work? Any help?
souheil - Sunday, January 9, 2011 6:53 PM:
check this post
http://www.aras.comhttp://www.aras.com/Community/forums/p/1276/3780.aspx#3780
