SUPPORT Q&A - new install, 500.19 error
VSR - Thursday, February 10, 2011 12:55 AM:
I trying to run Aras in Windows 7 with IIS 7.5. I have installed it but I get an error when I try to access localhost/.../default.aspx. Below are the details:
 Requested URL localhost:80/.../default.aspx
Physical Path C:Program Files (x86)ArasInnovatorInnovatorServerdefault.aspx
Logon Method Not yet determined
Logon User Not yet determined
 Module IIS Web Core
Notification BeginRequest
Handler Not yet determined
Error Code 0x80070021
Config Error This configuration section cannot be used at this path. This happens when the section is locked at a parent level. Locking is either by default (overrideModeDefault="Deny"), or set explicitly by a location tag with overrideMode="Deny" or the legacy allowOverride="false".
Config File \?C:Program Files (x86)ArasInnovatorInnovatorweb.config
Config Source
    3:   <system.webServer>
    4:     <handlers accessPolicy="Read, Script" />
    5:     <directoryBrowse enabled="false" />
Please help.
Thank You,
Venkat
VSR - Thursday, February 10, 2011 8:37 AM:
I don't think I have my IIS server/.net framework completely configured. I did not have ASP.NET installed and I had to add that on top of .installing net framework. But now I get a new error:
HTTP Error 404.17 - Not Found - Static File Handler. I don't think I have configured my web server to run .aspx. I ran the aspnet_regiis -i tool in .net Framework 4.0, but that has not fixed the issue.
Thank You,
Venkat
PS: I think the Documentation needs more detail on configuring IIS server.
authentic - Monday, August 15, 2011 3:49 AM:
bgfTiger2:
Christian Louboutin UK is here waiting for you with open arms. A lady with a high temperament would love the Christian Louboutin Shoes. Those are the the kind of shoes like the Christian Louboutin Bridal that will distinguish you from others and make you unique and the centre of the spotlight. Ladies have been working just as hard, if not harder, like their male colleagues, so, they should learn how to treat themselves to the best Louboutin Peep Toe that the world has to offer. In any Christian Louboutin Outlet there would be ladies of all ages swarming in to grab a pair of their favourite Christian Louboutin Pumps. The choice of the majority could not be wrong for sure. The Christian Louboutin Wedges and the Christian Louboutin Slingback are a great choice this season, trailing a breeze of high and noble air wherever they go, leaving the men inquistive and eyes following them till they disappear in the horizon. The atmosphere wave along with those fabulous Christian Louboutin Boots. Walking and swaying down the road, no one could possibly miss the dazzling light coming from the Christian Louboutin Sandals on your feet. You leave the man wondering where this dazzling lady came from and the woman all green in the eye. Not to disappoint the men, Christian Louboutin Men have been introduced to satisfy the men.
Ronan - Thursday, February 10, 2011 10:16 AM:
As far as I know, Innovator 9.2.0 won't run under IIS 7.5, meaning no 2008R2/Seven at the moment. The supported server platforms are:
  • IIS6 under 2003Server
  • IIS7.0 under 2008Server *R1* (not R2)
PatrickW - Tuesday, February 15, 2011 7:50 AM:
I installed Aras Innovator 9.2.0 on Windows 2008 Server R2, IIS7.0 in a Virtual PC and it works just fine.
/Patrick
VSR - Thursday, February 17, 2011 9:06 AM:
I just got Aras to work on my Windows 7 desktop with IIS 7.5. IIS did not have ASP.NET installed by default and I had to enable it via the Turn Windows Features On or Off tool.
