DEVELOPERS FORUM - Help me using Solution Upgrade Tool build 5560- Bad Property Name error
AshokGopale - Thursday, February 10, 2011 1:32 AM:
Dear all,
I have innovator 9.2 installed.
I have downloaded and trying to import a community project "WorkflowAutomation examples" using Solution upgrade Tool -import utility.
But it gives me following error
faultString:RecurseCheck
faultdetail:Bad property name default_lifecycle for type ItemType
faultcode=-1
The settings were like this
1) Type=ignore
2)mode=thorough mode
I seached the aras forum for the above said error , i found some users have also posted the simillar error
but  these are not answered.
So i have posted  my error, can any body tell me where i am wrong or how can i import the above said project in my innovator.
Thanks and Regards,
Ashok
raviraj - Thursday, February 10, 2011 3:28 AM:
Hello Ashok
This case will be occur  mainly when in your Itemtype dont have the Property of Same name that  u r Importing... Confirm that first.
Raviraj
Ronan - Thursday, February 10, 2011 10:22 AM:
Hi Ashok,
As you can see in the community solution download page of the "Workflow Automation Examples" this solution is not up to date (supports 9.0.2) and schema changes causes it to fail to import.
I also used this solution a few days ago, did the required changes and sent them to Aras, you can expect an update soon working in 9.2.0. Or drop me an email I'll send you the updated package.
