SUPPORT Q&A - Authentication Failed
suzbandit987 - Friday, July 13, 2007 3:16 PM:
Well after I learned some things from a different Open Source program installation, I got past my Innovator .net issues.  Now I am getting the authentication failed error meassge when I try to login.  I have read all the posts I could find on this issue, but still cannot get it to work.  Can we go through the motions, here as well???
Here is my InnovatorServerConfig.xml
<Innovator>
  <UI-Tailoring login_logo="../images/logos/innovator_splash.jpg" branding_img="../images/logos/banner_02.jpg" product_name="Innovator 8" banner_url="../scripts/banner.aspx" banner_height="50" />
  <operating_parameter key="debug_log_flag" value="false" />
  <operating_parameter key="debug_log_limit" value="10000" />
  <operating_parameter key="debug_log_pretty" value="true" />
  <disabled_operating_parameter key="performance_logging" value="cpu" />
  <operating_parameter key="xslt_processor_debug" value="false" />
  <disabled_operating_parameter key="email_debug_option" value="file" />
  <License lic_type="Unlimited"lic_key="7f100b7b36092fb9b06dfb4fac360931" />
  <Mail SMTPServer="queue" />
  <operating_parameter key="temp_folder" value="C:Program FilesArasInnovatorInnovatorServer emp" />
  <operating_parameter key="ServerMethodTempDir" value="C:Program FilesArasInnovatorInnovatorServerdll" />
  <operating_parameter key="debug_log_prefix" value="C:Program FilesArasInnovatorInnovatorServerLogs" />
  <DB-Connection id="InnovatorSolutions" database="InnovatorSolutions" server="jeff/sqlexpress" uid="innovator" pwd="innvator" dbType="SQL Server" />
</Innovator>
Bill - Friday, July 13, 2007 3:57 PM:
Well, I'm not sure which error you are getting, but let me try to pass on a couple of ideas that might help.
"Authentication failed for..." usually means that you have simply used an invalid login/password.  In this case, please refer to post http://exchange.aras.com/forums/post/82.aspx for help logging in the first time.  You can also review Section 4 "Logging into Aras Innovator" in the Aras Innovator - Installation Guide on our documentation page at:  http://www.aras.com/support/Documentation/documentation.aspx
If you get an error message like the following:
 Login Failure
It indicates that the db connection string is incorrect.  The most likely error is that the login and passwrod are not correct.  To change this, edit the InnovatorServerConfig.xml, and find the connection parameters for the database you are trying to log into:
<DB-Connection id="InnovatorSolutions" database="InnovatorSolutions" server="localhost" uid="admin" pwd="innovator" dbType="SQL Server" />
In this case, it is an example from a different community member in the past.  He had substituted the Innovator Admin login information for the sql login information.  When you installed the database, you created the innovator user, and assigned him a login.  The default value for this login is "innovator".  So I would change the connection string to match what I set it to when it was originally installed.
<DB-Connection id="InnovatorSolutions" database="InnovatorSolutions" server="localhost" uid="innovator" pwd="password" dbType="SQL Server" />
If you do not remember what you set the password for the login to, I recommend that you reset the password in SQL Server.
For more information about configuring the InnovatorServerConfig.xml parameter, see the Aras Innovator - Installation Guide on our documentation page at:  http://www.aras.com/support/Documentation/documentation.aspx
If the error you are recieving is not any of these, please give me the text of the error message, and I'll be glad to help.
-Bill
authentic - Monday, August 15, 2011 4:03 AM:
aTiger5:
The other day, as I was surfing the net, I came across those really fabulous footwear that caught my whole attention at once, the Supra Shoes UK. Yes, you are not mistaken, it is the Supra Shoes that I¡¯m talking about. The company, as a matter of fact, excels in making all kinds of shoes for all age groups and both genders. For example, the Supra Vaider UK is an excellent shoe, comes in all colours and sizes. Supra Skytop Shoes is an excellent shoe to wear when out in the wild, be it having a picnic in the park, strolling a hike in the woods, or even climbing the mountains to challenge oneself. Supra Skytop 2 makes an excellent companion no matter where you are. Another option, or I would say, another of my favourites, is the Supra TK Society that is well-knowned for their uniqueness and special designs. Having such wonderful Cheap Kids Supra for your kid would make them really happy and feel their parents love around them more than ever. Such shoes are right for all occasions and they are comfortable to wear. Supra Shoes Sale definitely is a not to miss.
suzbandit987 - Friday, July 13, 2007 4:03 PM:
How do I reset the password for SQL?
Bill - Monday, July 23, 2007 4:51 PM:
Have you manually edited this config file?
This line has two suspect things for me:
server="jeff/sqlexpress" should probably be server="jeffsqlexpress"
pwd="innvator" is correct?  have you tried to login to the management console using this password?
-Bill
square - Wednesday, June 8, 2011 12:09 PM:
I have installed Aras Innovator successfully, but the first time login, I used user 'admin' and password 'innovator', but I got an error message window with  "Login failed for user "innovator" ".  I have read the "Aras Innovator 9.2 - Installation Guide.pdf", this is the default login account, I am not sure what I have missed.  Has anyone encountered this problem before?  Any help will be appreciated.  Thanks,
Ronan - Wednesday, June 8, 2011 2:13 PM:
Hi.
See this.
