SUPPORT Q&A - Innovator Initialization Error
ashhadvv - Tuesday, February 15, 2011 2:06 AM:
After reinstalling Aras, when I am trying to open it I am getting an error message as follows
Resource with key="'system_requirements.failed_initialize_innovator'" is not found in "localhost/.../ui_resources.xml".
Resource with key="'system_requirements.controls_load_error'" is not found in localhost/.../ui_resources.xml".
The component versions are as follows
Innovator---->9.1
IE ---->6.0
.Net Framework-->2.0
Please suggest a solution for this.
Thanks in advance!!!
SamsAn - Thursday, February 17, 2011 3:54 PM:
Hi.
Probably, you modified ui_resources.xml before reinstalling of Innovator. Thus this file was not overridden with appropriate version during reinstallation. I recommend to remove (or rename) ui_resources.xml and reinstall again.
SamsAn.
