SUPPORT Q&A - Logging in problem - "Invalid object name 'USER' "
piotrj - Wednesday, February 16, 2011 1:40 PM:
I've downloaded and installed a test instance of Innovator 9.2.
Client runs, but when I'm trying to login into the system, I'm getting every time the same error with message "Invalid object name 'USER' ".
In the database everything seems to be OK. I'm logging in with user "vadmin", and 2 other passwords - first one "vadmin", and the second one "innovator". Without success.
I've also another one, but related question - is there any solution to change user password directly from the database layer? A stored procedure, function or something?
I will be very gratefull for your answers!
Kind regards,
Piotr
SamsAn - Thursday, February 17, 2011 3:55 PM:
Hi.
This can help: www.aras.comhttp:/.../1391.aspx
SamsAn.
authentic - Monday, August 15, 2011 3:49 AM:
fbhgTiger2:
Christian Louboutin UK is here waiting for you with open arms. A lady with a high temperament would love the Christian Louboutin Shoes. Those are the the kind of shoes like the Christian Louboutin Bridal that will distinguish you from others and make you unique and the centre of the spotlight. Ladies have been working just as hard, if not harder, like their male colleagues, so, they should learn how to treat themselves to the best Louboutin Peep Toe that the world has to offer. In any Christian Louboutin Outlet there would be ladies of all ages swarming in to grab a pair of their favourite Christian Louboutin Pumps. The choice of the majority could not be wrong for sure. The Christian Louboutin Wedges and the Christian Louboutin Slingback are a great choice this season, trailing a breeze of high and noble air wherever they go, leaving the men inquistive and eyes following them till they disappear in the horizon. The atmosphere wave along with those fabulous Christian Louboutin Boots. Walking and swaying down the road, no one could possibly miss the dazzling light coming from the Christian Louboutin Sandals on your feet. You leave the man wondering where this dazzling lady came from and the woman all green in the eye. Not to disappoint the men, Christian Louboutin Men have been introduced to satisfy the men.
piotrj - Friday, February 18, 2011 1:16 PM:
Still the same error.
PatrickW - Monday, February 21, 2011 2:36 AM:
Hi Piotr,
I suspect a database problem. If http://www.aras.comhttp://www.aras.com/Community/forums/t/1391.aspx didn't help, then the problem may be one of these:
  • the db user "innovator" you are connecting as does not have SELECT, UPDATE, INSERT, DELETE, EXEC permissions on the 'USER' table;
  • you aren't logging in / connecting as the "innovator" user;
  • you accessing the "USER" object without "innovator" being the owner;
  • you are connected to the wrong database;
Probably the first bullet point is the actual problem at hand. Please make sure the "innovator" user is the "InnovatorSolutions" database owner and has the appropriate rights.
You could also try to create a new Innovator instance from scratch using the same MS SQL Server Express installation.
/Patrick
