SUPPORT Q&A - .net Issues
suzbandit987 - Monday, July 9, 2007 4:21 PM:
I am still having .net issues.  I have this innovator software installed on a single user pc currently, so everything is local.  When I try to browse to innovator, I get "Innovator client has failed to initialize."  I don't see the gray text box that details any .net problem, I just get a blank white webpage with a red triangle, and the message I mentioned earlier.  Please help!  Thanks
snnicky - Tuesday, July 10, 2007 2:47 AM:
Hello.
Please describe the details of your Innovator installation. What options did you use during installation ? Did you perform any manual setups ?
I recommend you to check your IIS settings for all Innovator virtual folders. Check "Execute Permissions" setting for all of Innovator IIS virtual folders.
The permissions must be Scripts only and not Scripts and Executables.
Please let us known the results.
suzbandit987 - Tuesday, July 10, 2007 12:13 PM:
I checked the execute permissions and they were set to scripts and executables.  This did not fix my problem, though.  The options I chose during install??.....uh.....I did your typical installation with the msi.  I setup one database, Is there something specific your looking for about my installation?  Thanks in adavnce
I checked the execute permissions and they were set to scripts and executables.  This did not fix my problem, though.  The options I chose during install??.....uh.....I did your typical installation with the msi.  I setup one database, Is there something specific your looking for about my installation?  Thanks in advance
snnicky - Wednesday, July 11, 2007 1:48 AM:
Just to ensure we are on the same page: The permissions must be Scripts only. Otherwise Innovator will not work. According to your words installer failed to set  the permissions in correct way. I supposed you modified the permissions manually thus I asked if you did any manual setups.
suzbandit987 - Wednesday, July 11, 2007 2:50 PM:
Yes we are on the same page.  I assume that when I did the installer it set permissions to script only.  I probably got desperate and tried scripts and executables.  At any rate, they are now changed back to scripts only, and i am still having the same error.
snnicky - Thursday, July 12, 2007 2:29 AM:
According to the initial post it looks like .Net controls are not downloaded to your client computer.
Could you try to download one of controls ? For example if you login to innovator using URL http://MyServer.com/Innovator try to download one of controls accessing the URL http://MyServer.com/Innovator/Client/cbin/Vault.dll. The dll file must download successfully.
