spolen - Monday, February 21, 2011 9:00 AM:
I have been asked by several team members to delete parts and documents from the db and do not want to do this for reasons of history and in case they want to use these parts in the future.
Is there a way in the workflow to take a part from released to obsolete? I have done some reseach, but have been unable to do so.
thanks,
PatrickW - Monday, February 21, 2011 2:26 PM:
You will need to define some kind of final status - e.g. "closed", "obsolete", "end-of-life" - in your part and document life cycle and create a path between these statuses. This can be done in the respective LifeCycleMap. You can even let the status change (e.g. from "released" to "obsolete") set security on the item in a way it will not be visible for the users anymore.
/Patrick
authentic - Monday, August 15, 2011 3:53 AM:
dgvfgTiger3:
A woman has all the right to be nice to herself. Thus, the Christian Louboutin Boots come into the spotlight. Any lady should make herself comfortable and happy and buy all that she wants with her hardearned money. Thus, she should get herself a pair of Christian Louboutin Pumps to wear to the parties. This may be least she could do for herself, making herself sparkle and bright and beautiful.The Christian Louboutin Canada is a wonderfal maker of women shoes. He knows the needs of ladies and thus, knowing the right shoes that ladies would love. The Christian Louboutin Peep Toe is a good choice to wear on the hot summer evenings. Christian Louboutin Bridal will help make your leg long and slender and sexy, attracing the eyeballs of all those around you and getting those envious eyes of your fellow ladies, making you the pretiest bride ever. So what are you waiting for? The Christian Louboutin Sale provides you with a wide variety of wonderful Christian Louboutin Slingbacks and Christian Louboutin Sandals for you to choose from. Not to forget there is also Christian Louboutin Mens for the men. You are sure to be able to find your dream Christian Louboutin Wedges here.
spolen - Tuesday, March 22, 2011 11:10 AM:
Thank you Patrick,
I did update the life cycle for both the part and document and still in the State I am unable to promote to Obsolete. Any other suggestions on what I may be doing wrong. In lists, I thought maybe I could add the state of Obsolete, but have been unable to find the state properties anywhere.
PatrickW - Tuesday, March 22, 2011 11:56 AM:
Hi Sue,
The next thing I can think of is that you are not part of the "role" that is set on the transition. In that case, you will not see the transition. Open the life cycle map and click on the transition line. You should see the role that's allowed to promote the item.
- Patrick
SKolbe - Wednesday, March 23, 2011 9:24 AM:
Hi Sue,
did you check what Patrick proposed? This sounds meaningful for me, too.
Note that the default LC map for Parts & Documents has states
Preliminary - In Review - Released - In Change - Superseded.
And there is a corresponding Workflow Map controlling the LC states, i.e by completing the workflow map (here: ECN) the LC state transitions are done by application. So it takes 1 ECN to bring Parts/Documents from state Preliminary to Released (action: ADD) and another ECN to bring Parts/Documents from Released to Superseded (action: DELETE).
Or do you have complete different customization of you Part/Document lifecycle & workflow ???
Regards Stefan
spolen - Tuesday, March 29, 2011 12:09 PM:
Hi All:
I checked Patrick's role as suggested, and being I am CM and the admin for Innovator, it does show CM when I go to the role. I am working in a test db for this and the states for these are not customized and are standard, so I am still at a deadlock in regards to this state.
Sue
