suzbandit987 - Monday, July 23, 2007 4:22 PM:
I have done everything in the aras documentation necessary to setup a client. I have read all of the other posts and still no luck. I have tried setting up mulitple pc's. I cannot get any of them to work. Is there some other things I may try that are not listed in the documentation?Bill - Monday, July 23, 2007 4:48 PM:
If you open up the SQL Server Management Studio, can you log in with the following credentials?
Server Name = jeffsqlexpress
Authentication = SQL Server Authentication
Login = innovator
Password = innvator
If so, can you see the InnovatorSolutions database in the object explorer?
If so, can you view the User table?
-Bill
suzbandit987 - Monday, July 23, 2007 8:27 PM:
Yes I can see all of that. I do have full access to the innovator database. Note, that I (obviously) logged into the database from my server, not from a client machine. Also I can get to innovatorserver/clients/scripts/innovator.aspx from my server, just not clients. Thanks.Bill - Monday, July 23, 2007 8:30 PM:
What error do the clients give you, then? I'm obviously a thread behind.
suzbandit987 - Monday, July 23, 2007 8:49 PM:
It's the same old gray box that basically says .net security not set. It's been documented here in the posts at least three times, and I have read through all of those and still it is not working. I believe the old threads are #'s 66 and 67.Bill - Monday, July 23, 2007 8:59 PM:
There was a log created when you ran the sdns.exe tool on the client PC's. (Either sdns.NET 1.1.log or sdns.NET 2.0.log)
Could you read that log and confirm it has a message like this (Please don't post your the log contents if it uses a public URL.):
Setting security for .NET 1.1 ...
Create new group with name "server/.../" ...
Microsoft (R) .NET Framework CasPol 1.1.4322.573
Copyright (C) Microsoft Corporation 1998-2002. All rights reserved.
Added union code group with "-url" membership condition to the Machine level.
Success
suzbandit987 - Monday, July 23, 2007 9:02 PM:
Here is what is in my 2.0 log(I also have 1.1)
Setting security for .NET 2.0 ...
Create new group with name "http://ip address/innovatorserver/client/scripts/innovator.aspx" ...
Microsoft (R) .NET Framework CasPol 2.0.50727.42
Copyright (c) Microsoft Corporation. All rights reserved.
Success
My machine's IP Adress was obviously in the code group name originally, I deleted it. Thanks for the head's up on that one.
Bill - Monday, July 23, 2007 9:09 PM:
That's your problem. You are using the wrong URL.
You need to rerun the sdns.exe using the URL http://ip address/innovatorserver
This is also the URL you should be using to connect to Innovator in internet explorer.
-Bill
suzbandit987 - Monday, July 23, 2007 9:21 PM:
Thanks. That did it. Thanks for your help.
