pinakpatel - Friday, April 8, 2011 2:37 AM:
Hi Friends,
I am stuck with problem of check-in file by code.
To check-out file,There is a ready-made function --->checkout()
But
How to check-in files through code. it should check in files in such a manner that maintain its
Generation and Revision.
Thanking You.
Triadian - Monday, May 16, 2011 8:13 AM:
This post may be helpful http://www.aras.comhttp://www.aras.com/Community/forums/p/1099/3235.aspx#3235
Goodluck
pinakpatel - Tuesday, May 31, 2011 4:10 AM:
Hi Triadian,
thanks for help,
but i want something more which maintains its revision and generation.
Pinak Patel
Triadian - Monday, June 6, 2011 12:28 AM:
Hi Pinak,
You can set the version attribute to 0 and use update ,if you don not want to update Revision and generation.For Example:
locked_Item.attachPhysicalFile(FullPath); locked_Item.setAttribute("version", "0");
pinakpatel - Monday, June 13, 2011 7:17 AM:
Hi triadian,
Can you please send me your e-mail id,
so i can send you one full document of my problem statement.
Thank You very much...
Pinak
