DEVELOPERS FORUM - Problem with Accessing Innovator Server from Client Machine
vishal_trivedi - Monday, April 18, 2011 10:35 AM:
Hi Community,
I have a problem in accessing InnovatorServer  from client machine.
E.g.
1) I have a PC1  in which i have installed ARAS and I am accessing it from client C1 machine then it is working fine.
2) Also there is an another PC2 on which ARAS is installed and when we are trying to access it from the same client C1 from where we can access Innovator on PC1, it reaches to Login page where it keeps on loading Activex and doesn't allow to proceed further.
Thanks in Advance,
Vishal
eric_h - Monday, April 18, 2011 4:03 PM:
Vishal,
I am sort of new to Aras myself, but I thought I would share my first thought in case it was the issue. The "sdns.exe" utility, which I believe serves the function of setting .NET zone security levels works on a per server/location basis. So if you ran "sdns.exe" to setup C1 to access PC1, you would also need to run it again on C1 for the URL that accesses PC2. This is just a thought, and might not be totally correct, but wanted to share.
Eric
vishal_trivedi - Tuesday, April 19, 2011 12:47 AM:
Hi Eric,
You are right.
But, I tried that option many times before but it wasn't helpful.
I need some other solution.
Thanks for you effort.
Vishal
eric_h - Tuesday, April 19, 2011 1:05 PM:
After I posted, I saw you had over 40 posts and figured you probably already knew what I said. Oh well, worth a try. Hopefully someone else has some suggestions.
Eric
