DEVELOPERS FORUM - Remote Debugging in Win7 & VS2010
Nick - Monday, April 18, 2011 2:38 PM:
After figuring out that the programmers manual was outdated, I had to fool around with things to get this working for myself. Just thought I'd post how I did it so others could give it a try.
Note: You don't need to do this if the server is local, just turning on Just-In-Time debugging will work if you add the line 'System.Diagnostics.Debugger.Break();' into the code. Otherwise attach to the process 'w3wp.exe'. Also I'm pretty bad at explaining things for the most part, so feel free to point things out.
Also, the process 'w3wp.exe' will only run once you have Innovator open and are trying to run code, as far as I've found at least.
First set up Remote Debugger on the server computer. Make sure to uncheck the 'run as a service' option.
http://msdn.microsoft.com/en-us/library/bt727f1t.aspx
Now run Visual Studio 2010 Remote Debugger, go to Tools -> Options and set it to No Authentication and choose a port, then set it back to Windows Authentication. (for some reason we couldn't get it to connect with No Authentication O_o)
Then set up the firewall, using the port you selected above instead of the one it tells you to use.
http://msdn.microsoft.com/en-us/library/ee126350.aspx
Once that's done open up your Control Panel, go to Administrative Tools then run Computer Management. In here open up Local Users and Groups and click on Users. Go to Action -> New User and add an account that has exactly the same username and password as the one you use to log into the computer you're trying to debug remotely from. Once that's done make sure the user is in the Administrator group and close that window.
Now open up Internet Information Services from the Administrative Tools window and press the arrow next to your computer name on the right. Choose the first option under your computer name, right click on Aras Innovator AppPool ASP.NET 2.0, go to advanced settings. Scroll down to Ping Enabled and switch it to false, and set Ping Maximum Response Time to 300 or greater.
Lastly open up 'C:Program FilesArasInnovatorInnovator' and share either the 'Server' folder or the 'Serverdll' folder so that the remote computer can find the source file to look at.
Log into your Innovator server (hopefully a test environment!) and run Visual Studio 2010 on the remote computer, then go to Tools -> Attach to Process and in the Qualifier box put the the server name that Visual Studio 2010 Remote Debugger shows to connect to. Select 'w3wp.exe' and hit attach. Now if there's an error or you have the line 'System.Diagnostics.Debugger.Break();' in your server side code it should automatically open up in VS2010.
Wall of Text crits readers for 20k! Anyway, tell me if that works for anyone else, or if it's too confusing to understand. That's what we had to do to get it to work. Enjoy.
amiao - Thursday, August 8, 2013 11:21 PM:
Hi Nick,
I have tried as you say, but VS2010 can't open source code when the debugger starts. it occured this error:No available source.
can you help me?thanks
Eric Domke - Wednesday, August 14, 2013 1:35 PM:
What I have done with our servers is set up sharing on the Innovator folder so that any admin on the server can access the innovator folder using a UNC file path.  Therefore, in order to navigate to the source code when prompted by VS2010, all you need to do is to find the appropriate file under \{your server}InnovatorInnovatorServerdll.  Once you do this a couple times, VS2010 tends to remember where the source code is located.
Eric Domke - Wednesday, August 14, 2013 1:37 PM:
Nick mentions this in his post.  I guess it would help if I read everything before writing a reply...
