DEVELOPERS FORUM - Returning Null Exception when adding Item using AML....
raviraj - Tuesday, April 19, 2011 9:51 AM:
Hello All
I m adding Item Using AML
string _newBomCompRel = "<AML>" +
                                                   "<Item type = 'ahi_part_request' action = 'add'>" +
                                                      "<related_id>" + compId + "</related_id>" +
                                                      "<source_id>" + assmblyId + "</source_id>" +
                                                   "</Item>" +
                                                  "</AML>";
                Item newBomCompRel = MyInnovator.applyAML(_newBomCompRel);
When i run this it Retrns the Error "NullReference Exception was Unhandled"
Object reference not set to an instance of an object.
do anybody know this ..... Please Help.....
Brian - Tuesday, April 19, 2011 10:03 AM:
Hi Raviraj,
First check that the AML works from the NASH script. Then you will know if the AML is correct.
I suspect that "MyInnovator" has not been created correctly. You should try to debug the code so that you can see what is actually happening.
