Tattieee - Monday, May 9, 2011 7:37 AM:
Hi guys,
I managed to install Innovator with no hitches however when I try to run it in IE8 I just get a blank page that repeatedly says connecting during redirecting stage.
I've installed Innovator before but never encountered this issue, I was wondering if anyone could help me out.
Thanks in advance
Operating System: Windows Server 2008
Tattieee - Tuesday, May 10, 2011 5:09 AM:
In fact now when I try to login via localhost/.../InnovatorServer.aspx I get the following error:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="schemas.xmlsoap.org/.../">
- <SOAP-ENV:Body>
- <SOAP-ENV:Fault xmlns:af="www.aras.com/InnovatorFault">
<faultstring>The Database is not available.</faultstring>
- <detail>
<af:legacy_detail>The Database is not available.</af:legacy_detail>
</detail>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Any help would be appreciated.
authentic - Monday, August 15, 2011 3:59 AM:
7888Tiger4:
Moncler name came from the abbreviation in Monestier de Clermon. Our Moncler Outlet specializes in the production of outdoor sports equipment. We provide the Cheap Moncler Jackets you will just love. Our Moncler Jackets Outlet is secured and trusted by the world. Our products reach a large variety, including vests for all ages, such as the Kids Moncler Jackets which looks wonderful on the little boys and girls. Also, come and take a look, you will find the one Moncler Jackets For Women made just for you. Moncler went through a long history to reach its place today. Our Moncler Jackets Men and Moncler Shirt Women are up to date with the latest fashion trends. At the same time, Moncler Vest Men and the Moncler Vest Womens is made from the best materials and can keep you away from the harms of the bitter cold this coming winter. If you are a person extremely afraid of the cold like me, I would recommend you the Moncler Scarf which will keep your neck cosy and warm in the snow. Another one of my favorites is the Women Moncler Long Down Jacket which can give you the mysterious look as you stroll down the path in the white snow.
Ronan - Tuesday, May 10, 2011 9:21 AM:
Does the database mentioned in the database dropdown menu of the login screen exist? If no, open C:Program FilesArasInnovatorInnovatorServerConfig.xml and adjust the <DB-Connection ....> line to include an existing database. If yes, is SQLServer up and running? (can you connect to it through Management Studio?).
Tattieee - Tuesday, May 10, 2011 9:48 AM:
Hi Ronan,
I have yet to see the login screen appear, I get the error listed in my second post when I try to visit the URL, the innovator login screen doesn't show up.
I am able to connect to SQLServer through Management Studio. One thing I do noticed in Management Studio is that SQL Server Agent is not running, I am not sure if this will be relevant. I have tried starting it but I get an error also.
This is the line from my .xml:
<DB-Connection id="InnovatorSolutions" database="InnovatorSolutions" server="(local)" uid="innovator" pwd="innovator" dbType="SQL Server" />
which is all correct as far as I am aware.
Thanks in advance.
Ronan - Tuesday, May 10, 2011 10:04 AM:
Oh, I misread your initial post. You are just trying to connect through an invalid URL!
You should not use localhost/.../InnovatorServer.aspx , but localhost/.../
Tattieee - Tuesday, May 10, 2011 10:38 AM:
Thanks Ronan,
When I follow the link I'm met with a redirect which as far as I remember should load me into the Innovator login, however I get an error during this process:
And the redirect page continues to sit blank.
Not sure if this is something wrong with my installation or with IE.
Thanks in advance
Ronan - Tuesday, May 10, 2011 10:52 AM:
Try this workaround. You can also try to open localhost/.../Innovator.aspx
Tattieee - Tuesday, May 10, 2011 11:04 AM:
Great stuff! Working :)
Thanks for all your help Ronan!
