DEVELOPERS FORUM - onAfterGet property link
scottmahr - Wednesday, May 11, 2011 1:32 PM:
I want to put a "ball in court" property on my ECO itemType.  I added the property with a Data Type of Item and a Data Source of Identity.  I use an onAfterGet server method to find who is next up in the workflow.  I then fill in the ball_in_court field.  I would like to have it display the identity name, but link to the identity when clicked.  If I fill in the field with the identity ID, the link works fine, but it displays the ID.  If I fill in the name, it looks fine, but doesn't link.  The identity item type has the correct Keyed Name Order set, as all my other identity fields work fine.  I think the issue is me setting the property after it is received.
Any help would be great, thanks,
Scott
scottmahr - Wednesday, May 11, 2011 1:50 PM:
Figured it out, for anyone who might have the same question:
Looking in an AML response I found
<permission_id keyed_name="In Work Change" type="Permission">AEBC0BC7518F4CF58936EACDAAD2AB8E</permission_id>
Obviously, I needed to set attributes of the property and leave the id as the value.
workflowItem.setProperty("ball_in_court", iden.getProperty("id"));
workflowItem.setPropertyAttribute("ball_in_court","keyed_name",iden.getProperty("name"));
workflowItem.setPropertyAttribute("ball_in_court","type","Identity");
Scott
