DEVELOPERS FORUM - Server Report Errors
scottmahr - Tuesday, May 17, 2011 1:37 PM:
When ever I try to run a report that runs on the server I get the following error.
"Error occurred while creating MSXML COM objects. Code: 0xc0000073 Could not create the 'MSXML2.DOMDocument.4.0' object. Make sure that MSXML version 4.0 is correctly installed on the machine. Error occurred while creating MSXML COM objects. Code: 0xc0000073 Could not create the 'MSXML2.DOMDocument.4.0' object. Make sure that MSXML version 4.0 is correctly installed on the machine. "
I have installed msxml4 on both the client machine and the server (I think).  Any ideas on how to start to troubleshoot this?
Scott
Ronan - Tuesday, May 17, 2011 10:02 PM:
MSXML 4.0SP2 can become picky sometimes; did you try to reinstall it?
Also, client-side reports work, right?
