eric_h - Tuesday, May 24, 2011 1:36 PM:
We have a centralized/shared MS SQL Server 2005 Standard Edition DBMS that might be ideal to use for Aras vs. installing a standalone instance. One question that came up, because the 9.2 platform specs doc recommends Enterprise Editions, can we run Aras on SQL Server 2005 Standard Edition? What would be the drawbacks? Are requirements for 9.3 going to change any in regards to this?
Also, it sounds like in time this shared/centralized SQL Server instance will be upgraded to 2008. Hopefully that is pretty easy.
Another related question I just thought of, but can we use Windows Server 2008 R2? Not sure if it being a 64 bit OS would cause any issues, though I assume it would run 32 bit applications fine. Just thought I'd check in this as well while I am at it. Aras will be installed as a VMware instance, and I was told that Windows Server 2008 R2 was the preferred OS at this time.
Eric
Brian - Friday, May 27, 2011 4:43 AM:
Hi Eric,
Yes you can run Innovator on SQL Server 2005 standard edition. Enterprise is better for the scalability factors. There was no mention of removing support for SQL 2005 in the updates for 9.3 so you should be safe there.
Upgrade to SQL 2008 should also not cause any problems.
Yes you can use Windows Server 2008 R2. Innovator installs to a different default directory and runs as a 32 bit app.
authentic - Monday, August 15, 2011 4:00 AM:
er888Tiger4:
Moncler name came from the abbreviation in Monestier de Clermon. Our Moncler Outlet specializes in the production of outdoor sports equipment. We provide the Cheap Moncler Jackets you will just love. Our Moncler Jackets Outlet is secured and trusted by the world. Our products reach a large variety, including vests for all ages, such as the Kids Moncler Jackets which looks wonderful on the little boys and girls. Also, come and take a look, you will find the one Moncler Jackets For Women made just for you. Moncler went through a long history to reach its place today. Our Moncler Jackets Men and Moncler Shirt Women are up to date with the latest fashion trends. At the same time, Moncler Vest Men and the Moncler Vest Womens is made from the best materials and can keep you away from the harms of the bitter cold this coming winter. If you are a person extremely afraid of the cold like me, I would recommend you the Moncler Scarf which will keep your neck cosy and warm in the snow. Another one of my favorites is the Women Moncler Long Down Jacket which can give you the mysterious look as you stroll down the path in the white snow.
