DEVELOPERS FORUM - Silverlight Security Error
Brian - Friday, May 27, 2011 1:31 AM:
Hi All,
I trying to learn a bit about using Silverlight as a client for Innovator.
I have downloaded the sample application from the Projects page but get a Security Error when I run it.
<SOAP-ENV:Fault xmlns:af="http://www.aras.com/InnovatorFault" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
  <faultstring></faultstring>
  <detail>
    <af:legacy_detail><![CDATA[System.Security.SecurityException: Security error.
   at System.Net.Browser.BrowserHttpWebRequest.InternalEndGetResponse(IAsyncResult asyncResult)
   at System.Net.Browser.BrowserHttpWebRequest.<>c__DisplayClass5.<EndGetResponse>b__4(Object sendState)
   at System.Net.Browser.AsyncHelper.<>c__DisplayClass4.<BeginOnUI>b__1(Object sendState)]]></af:legacy_detail>
    <af:exception message="" type="Aras.Server.Core.InnovatorServerException" />
  </detail>
</SOAP-ENV:Fault>
I'm running on Windows 7 and have confirmed that the Server URI, database and password are correct.
Has someone else got this working and can provide some tips to help me keep my hair?
essjay - Friday, January 27, 2012 12:32 PM:
Also having this problem. Did you solve it?
essjay - Friday, January 27, 2012 12:33 PM:
Did you solve it?
essjay - Friday, January 27, 2012 12:43 PM:
Hi. Did you solve this issue?
Brian - Sunday, January 29, 2012 6:09 AM:
This is to do with the Website setup not the code in the example.
You need to add the files:
Clientaccesspolicy.xml with content like:
<?xml version="1.0" encoding="utf-8"?>
<access-policy>
 <cross-domain-access>
  <policy>
   <allow-from http-request-headers="*">
    <domain uri="*"/>
   </allow-from>
   <grant-to>
    <resource path="/" include-subpaths="true"/>
   </grant-to>
  </policy>
 </cross-domain-access>
</access-policy>
and
crossdomain.xml with content:
<?xml version="1.0"?>
<!DOCTYPE cross-domain-policy SYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
 <allow-http-request-headers-from domain="*" headers="*"/>
</cross-domain-policy>
to the root of your website (probably c:inetpubwwwroot)
Then restart you web server.
cheers,
essjay - Monday, January 30, 2012 5:21 AM:
Brilliant, thank you very much. What I did for anyone in the same boat.
  1. Created both files as mentioned above and save them into "c:inetpubwwwroot"
  2. Copied the "Debug" folder from the sample code, dropped it into "c:inetpubwwwroot" and renamed it "Aras"
  3. Ran the file localhost/.../Sample_Silverlight_ApplicationTestPage.html
