SUPPORT Q&A - Microsoft .NET error
JoannaB - Wednesday, August 22, 2007 1:48 PM:
I have finally gotten Innovator installed, only to receive the following error upon login as admin:
Unhandled exception has occurred in a component in your application.  If you click continue, the application will ignore this error and attempt to continue.
The remote server returned an error:  (401)  Unauthorized
So, I click continue, and receive an outline of Innovator components in the left hand screen, but nothing shows up in the main window.  I found a posting in this forum dated 7-11-2007 from user prabhu with the exact same error, but there is no resolution posted.  I have tried contacting this user with no response.  Can someone else point me in the right direction?  (I also do not have a proxy server on the network...)
JoannaB - Wednesday, August 22, 2007 4:26 PM:
I have not received any replies.  I uninstalled Innovator and deleted the database.  The fresh install seems to have taken care of the problem.
