SUPPORT Q&A - IE Comes Up Blank/Empty
groufosse - Monday, June 20, 2011 12:13 PM:
Hi All,
After a normal install (update from 9.2) of Aras 9.3, I am trying to run Aras. The small login box appears, where I loging as admin/innovator. The IE page then goes fill-screen, but nothing appears but a dialog box stating "The webpage you are viewing is trying to close the window. Do you want to close this window?"
If I click NO, the page is blank - well, not totally. The top frame and side frame bars can still be seen. YES will close the IE browser.
Can anyone provide some insight to this issue? What has happened? In 9.2 ALl was well and I had in fact some data already in the database.
Thank you
Gary
groufosse - Wednesday, June 22, 2011 5:07 PM:
Normal 0 false false false EN-CA X-NONE X-NONE
Found the problem. For some reason, the browser service (IIS) didn't restart correctly after doing so manually. After doing that again, I finally got a full screen.
Gary
