DEVELOPERS FORUM - Data Type Suggestion
divya_p02 - Tuesday, June 28, 2011 7:26 AM:
Hi
I have two tables
Table 1 : Activity (Itemtype) where id is the primary key
Table 2 : Temporary(Itemtype) where id is the primary key
Requiremnt is
i want id of Table 1 (Activity) table to be referenced in Table 2 as a column and the column should be having id's of table 1
Example : Sample Table 1 Data
id                                                 Name
32bit integer                             Activity 1
Sample Table 2 Data
id                                                  Name                             Activity Id
32bit integer                              Temp Name                 32 bit Integer of Table 1
Please let me know approaches to acheive the same. My approaches are not able to fill the data in table 2 for Activity Id column, its getting null values. Reply soon as its very critical to proceed further.
Regards
Divya
fli - Thursday, June 30, 2011 9:47 AM:
Hi Divya,
The Activity could be a "rel to non" then having the Temp id as it's "source_id"
else maybe use a federated datatype property on the Temp Itemtype.
how shall this work ?
BR / Christoffer
