DEVELOPERS FORUM - populating a Federated property on the Activity2 itemtype
fli - Tuesday, June 28, 2011 9:24 AM:
Sadly I can't seem to understand how to use the federated property datatype.
I am trying to populate a federated property (spec_no) on the Activity2 Itemtype.
"spec_no" should be populated with data (name) from the "project" in which it is related.
Am I missing some data I should have made available from a OnBeforeGet event' __?
if someone would give a short example It would be great !
this is my best try:
server event OnAfterGet____________________________________________
if (this.isEmpty())
  return this;
for (int i = 0; i <this.getItemCount(); i++)
  Item myItem = this.getItemByIndex(i);
//////get project DATA
string myActID = myItem.getProperty("id","");
Item myWbsItem = this.newItem("WBS Activity2","get");
myWbsItem.setAttribute("select","source_id,related_id");
myWbsItem.setProperty("related_id",myActID);
myWbsItem = myWbsItem.apply();
if (myWbsItem.getItemCount()==1)   {
Item myProjItem = this.newItem("project","get");
myProjItem.setAttribute("select","name,wbs_id");
myProjItem.setProperty("wbs_id",myWbsItem.getProperty("source_id",""));
myProjItem = myProjItem.apply();
if (ProjItem.getItemCount()==1)   {
       myItem.setProperty("spec_no",myProjItem.getProperty("name",""));
return this;
Thank you very much
BR / Christoffer
Dave_Rollinson - Thursday, June 30, 2011 7:32 AM:
Christoffer
There are two problems in your Method:
1) The following section:
The "select" of "related_id" on "WBS Activity2" will cause a "get" of "Activity2", since you're using this Method as "onAfterGet" for "Activity2" this will cause an infinite loop.
2) This section:
The object "ProjItem" is not in context when you try to use it in the "if" statement; move the } to a point after the "if" block.
fli - Thursday, June 30, 2011 9:59 AM:
Hi David,
Thanks alot. tricky one...
Works perfecty.
BR / Christoffer
