DEVELOPERS FORUM - Executing Storedprocedure with IOM.dll
mengteh - Monday, September 17, 2007 8:54 AM:
 I would like to know whether it is possible to execute a storedprocedure in IOM.dll? And how?
 Thank you,
Meng.
SamsAn - Tuesday, September 18, 2007 8:38 AM:
Hi, Meng.
Ways to execute a sp:
1. Direct call from the db connection (not recommended) .
2. Using SQL ItemType and IOM Item.apply method. Details are below.
  2.1. Create Item of SQL type: go to Administration/SQLs of the main innovator tree, click Create a New Item and fill the appeared form. Save. The sp is created. Note: the sp has to return a recordset (use T-SQL code like: select 'success' as result_text).
  2.2. Create a new Method. Use the code (VB version) like below to call the sp:
   Dim itm as Item = me.newitem("SQL","SQL PROCESS")
   itm.setproperty("name","name_of_your_sp")
   itm.setproperty("PROCESS","CALL")
   itm.setproperty("ARG1", "value_for_the_first_arg")
   itm = itm.apply()
   if itm.isError() then
     return itm
   end if
Hope it helps.
mengteh - Friday, September 21, 2007 6:45 AM:
Yes, it helps. Thank you :D
