DEVELOPERS FORUM - Part field data and thumbnail Clear Issue
Stje_Cro - Monday, July 4, 2011 5:15 AM:
Hi all,
I have a couple of issues..
the first issue is that when i change the properties (for example the sort order of Part Number into Model ItemType)
into the item type as root user, I don't see the difference from state before the modification.
But if I make access with a different user (for example admin), after the modification is done, I see the difference from before modification.
The second issue is that i cannot save all data into the Part Form.
I have a field that is filled by an sequence but sometimes the field value should be modified by user or an JS method.
When I change this value and save the Part, the Part window is reloaded with old values.
This happens also with thumbnail Clear command.
When I push on Clear command the image disappear but when I save the Part and the window is reloaded, it is reloaded with the image.
If i modify the image and then save, when the window is reloaded it is reloaded with the new image.
