[email protected] - Wednesday, July 6, 2011 9:43 AM:
Hi, all:
I'm new to Javascript and also to ARAS development. I'm working with textboxes on a form and have written a method that will fire onBlur and manipulate the value of a text box, but without knowing its name or id ahead of time. Normally I would pass the word "this" to the function to identify the control that called it, like so:
<INPUT TYPE="text" ID="myText" NAME="myText" onBlur="formatText(this)">
...but I've been unable to figure out how to do that in ARAS. The method will always have to identify the control
that called it. Right now I call the method by adding a relationship to it in the field event of the text box
I'm trying to work with, and I don't see any way to insert the keyword "this". I've tried converting the text box to
an HTML object and adding "onBlur(this)" but I get an error saying an object was expected. How can I find the
identity or tag name of the field that called the method?
Jeremy
Brian - Thursday, July 7, 2011 11:31 PM:
Hi Jeremy,
Field events like onBlur receive a "this" context item from Innovator. The "this" context item for a field event is the Field Object that the event was called from.
So to manipulate the text you should just be able to use:
this.value = "My New Value";
Have you had a look at the Programmers Guide available on the Downloads : Documentation page?
http://www.aras.com/support/documentation/
[email protected] - Friday, July 8, 2011 8:57 AM:
Hi, Brian:
Thanks for getting back to me! I've tried several variations of that code and nothing works. I've tried several combinations including the following:
function myFunction()
this.value = "success";
and
function myFunction(t)
var field = t;
field.value = "success";
I'm sure I've got the method hooked up to the field correctly (I select the text field, add a relationship, select the method, select "onBlur" as the event) and I've got other methods that run fine. In the others I call out the control by tag name and I can find them and manipulate their values with no problems. In this case I will never know the name. Any suggestions?
Thanks again,
Jeremy
Brian - Friday, July 8, 2011 9:04 AM:
Have you just tried
No function declaration?
put alert("Method called");
just before the line so that you get feedback that the method is actually being called.
I tested this on a field. Added an onBlur event with only this.value = "something"; and it works for me.
[email protected] - Friday, July 8, 2011 9:34 AM:
Brian:
Thanks very much!! That was exactly the problem. Many points to you, sir.
-Jeremy
