DEVELOPERS FORUM - Unable to add File to Vault using AML
imitchell - Monday, August 8, 2011 2:27 PM:
Hello, I am trying to send a file remotely to the Vault Server using PHP and AML. I have used a Java example from this forum (www.aras.comhttp:/.../648.aspx as a guideline to send a multi-part request to the vault server. I am either missing something in the translation of the code or am missing a key concept. Here is the multi-part request that I am sending to the vault: ---------------------------BRdnIy5hBONlyI Content-Disposition: form-data; name="SOAPACTION"; Content-Type: text/plain ApplyItem ---------------------------BRdnIy5hBONlyI Content-Disposition: form-data; name="AUTHUSER"; Content-Type: text/plain admin ---------------------------BRdnIy5hBONlyI Content-Disposition: form-data; name="AUTHPASSWORD"; Content-Type: text/plain 41c3da4b71b56f14ba023025a8b73862 ---------------------------BRdnIy5hBONlyI Content-Disposition: form-data; name="DATABASE"; Content-Type: text/plain InnovatorSolutions91 ---------------------------BRdnIy5hBONlyI Content-Disposition: form-data; name="XMLDATA"; Content-Type: text/plain upload_junk-4.txt 14829413e11e3022433ae36a6237605b c: mpupload_junk-4.txt ---------------------------BRdnIy5hBONlyI Content-Disposition: form-data; name="14829413e11e3022433ae36a6237605b"; filename="c: mpupload_junk-4.txt"; Content-Type: application/octet-stream This is a junk test file used to test upload capability. Updated: 08/03/2011 12:07 pm ---------------------------BRdnIy5hBONlyI-- In response to this request, I get the following from the Vault Server: Server ProcessApplyItem: Invalid xml data (File upload_junk-4.txt not found) ProcessApplyItem: Invalid xml data (File upload_junk-4.txt not found) I am uncertain as to why the "file is not found" as it is being streamed to the vault server. I have tried a variety of perturbations to this code, some of which appeared to work as I received a Result Item, however, I was not able to find the file under the Vault directories. Any help that you can give would be greatly appreciated! Thanks, Jerry (using Ian's account)
imitchell - Monday, August 8, 2011 4:53 PM:
Here is a retry of that post!!!!
<pre>
ApplyItem
admin
99999999999999999999999999999999
<?xml version="1.0"?>
<SOAP-ENV:Envelope
xmlns:SOAP-ENV="SOAP-ENV='schemas.xmlsoap.org/.../'">
<SOAP-ENV:Body>
<applyItem>
<Item type="File" action="add">
<filename>upload_junk-4.txt</filename>
<id>14829413e11e3022433ae36a6237605b</id>
<actual_filename>c: mpupload_junk-4.txt</actual_filename>
<Relationships>
<Item type="Located" action="add">
<related_id>
<Item type="vault" action="get"/>
</related_id>
</Relationships>
</applyItem>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
</pre>
<pre>
<Fault>
<faultcode>Server</faultcode>
<faultstring>
</faultstring>
<detail>
<af:legacy_detail>
</af:legacy_detail>
<af:legacy_faultactor/>
</detail>
</Fault>
</pre>
imitchell - Monday, August 8, 2011 4:54 PM:
One last try without the pre tags
ApplyItem
admin
<SOAP-ENV:Envelope
<SOAP-ENV:Body>
<applyItem>
<Relationships>
<related_id>
</related_id>
</Relationships>
</applyItem>
</SOAP-ENV:Body>
<Fault>
<faultstring>
</faultstring>
<detail>
<af:legacy_detail>
</af:legacy_detail>
</detail>
</Fault>
