imitchell - Friday, August 12, 2011 7:13 AM:
After doing a fresh install (using existing BD) but I get an error box with the message below when I attempt to logon onto the Aras Innovator client. >>>>> Method not found: 'Boolean Aras.IOME.ItemCache.SetItem (System.Collections.ArrayList, System.Xml.XMLElement)' >>>>> I can click OK and continue on but I get the same error when I do browse the various Innovator folders on the left of the screen. On Windows 2003 Server Thanks, Ian
imitchell - Sunday, August 14, 2011 7:42 AM:
A little bump here...
I've noticed that initial Aras installs work ok (there are no "method no found" errors while using the Aras GUI).
But after I add my own software that accesses the IOM.DLL (for access by a different web app), the Aras interface runs into that problem. So I assume I must be clobbering .NET or IIS in relation to Aras. Incidently, that external access functionality works fine after I load it (but it clobber the Aras GUI).
One thing I was told to do by our previous Aras guy was to run gacutil on IOM.DLL and workflow.DLL, does that ring true with guy?
I'm hardly a Windows guy so I am reaching out- any thoughts on any of this?
