DEVELOPERS FORUM - "Bulk" delete with AML?
chado - Saturday, August 13, 2011 12:52 PM:
I'm working on cascading deletes of relationships to related Items (and relationship chains). I would like to be able to delete using AML, based on some criteria other than id.
e.g.
<AML>
   <Item type="someItem"  action="delete" where=" id IN (select...)>
or
<AML>
   <Item type="someItem"  action="delete">
   <source_id>[some known id]</source_id>
It seems that without providing a value for the id attribute, I get missing criteria exceptions no matter what I do. So is AML designed to only allow deletion of one Item at a time?
The "easy fix" is to use applySQL(..), but I am assuming that will circumvent the event model (verification of this notion would be appreciated), which is unacceptable.
So is this a semantics problem on my end, or are we forced to iterate, deleting one Item at a time? Framework client-server traffic is already very high, and we always worry about degrading performance further.
Any advice would be appreciated.
