sreerajav - Monday, August 22, 2011 8:57 AM:
I created new ItemType(TestItemType) with the following fields,
- item_number
- item_name
- item_cost
- item_description
- item_image
now i need to add/create instance to this new ItemType. I tried alot but unable to see the entry form/page for this new ItemType. Please help me..
Ronan - Monday, August 22, 2011 9:59 AM:
Hi Sreeraj,
You do this by defining a "TOC Access" and a "View" (Form). Go back to editing your ItemType, and here have a look at these tabs.
- TOC Access will ask you a Submenu and an Identity, letting you define where your ItemType should appear in the TOC (Table Of Contents) and who should have access to it
- Form will let you define the visual appearance of how your fields (to simplify) will be displayed.
That's it, try it and tell us how that worked.
sreerajav - Tuesday, August 23, 2011 3:20 AM:
Hi Ronan,
Thanks Ronan for your help.
Now i'm able to create instance to the newly added ItemType. The new ItemType is displayed in the Administration tab, so that i can easily add/create instance to that ItemType.. :)
I added New Relationship in the "TOC access" tab called Administrators and selected the category Administration
secondly, I added New Relationship in the "Can Add" tab Called Administrators and enabled Can Add feature.
Sreeraj.
