SUPPORT Q&A - Installation Help for BDC step?
shubhu2233 - Friday, August 26, 2011 6:24 AM:
 hi all
I have configured everything that mentioned in the document of aras integration with SharePoint. i have covered each and every step things looks fine working fine.
but the problem is that when go for  "Parts" external list then after processing i got following error:
"MethodInstance with Name 'ReadList' on Entity (External Content Type) with Name 'PartEntity' in Namespace 'Rzrlf.SP.Innovator.Bdc.PartBdcModel' failed unexpectedly. The failure occurred in method 'ReadList' defined in class 'Rzrlf.SP.Innovator.Bdc.PartBdcModel.PartEntityService' with the message 'The TEST requested login failed for user admin.'."
which credentials to pass in settings file
Currently i passed:
namespace Rzrlf.SP.Innovator.Bdc
    internal class Settings
        internal static string InnovatorDatabaseName
            get
                return "InnovatorSolutionsDB";
        internal static string InnovatorPassword
            get
                return Aras.IOM.Innovator.ScalcMD5("innovator");
        internal static string InnovatorServerUrl
            get
                return "192.168.10.152:420/.../Innovator.aspx";
        internal static string InnovatorUserName
            get
                return "admin";
please suggest me to rectify this problem.
Shubham
shubhu2233 - Monday, August 29, 2011 1:58 AM:
Please some body suggest me....
thanks
