APPLICATION - PRODUCT ENGINEERING - Assign sequence to subclasses
Charlatat - Tuesday, August 30, 2011 2:01 PM:
I believe its possible to have separate sequences assigned to subclasses. Is this correct? If so, I'm having troubles finding where to define that...
Brian - Thursday, September 1, 2011 7:26 AM:
Hi Charlatat,
I don't think there is a "configuration" that you can set to allow this.
I assume you want a sequence for the "item_number" for say a Part.
You can set the Item_number property as "string" and "not required". Then create a server event to be fired onBeforeAdd.
Read the classification "this.getProperty("classification","");"
and then call "getNextSequence("sequence name")  from the innovator item and assign it to "item_number" before returning from the method.
Hope this helps,
Ronan - Tuesday, September 6, 2011 9:02 AM:
Brian's right, this is not "out-of-the box" functionality, but is very easy to do with a small OnBeforeAdd method. I have C# code that does just what he described, here it is.
            string thisClassification = this.getProperty("classification");
            if (thisClassification == "Foo")
                string newNumber = inn.getNextSequence("PartFoo");
                this.setProperty("item_number", newNumber);
            return this;
