DEVELOPERS FORUM - Batch loading of Documents using http:// and SOAP
rif6894 - Friday, September 16, 2011 9:40 PM:
I have used the code in topic www.aras.comhttp:/.../1974.aspx to create a Document and upload the corresponding file - not a problem.
But the Document object is left in a 'locked' state, which I wish to remove using java with SOAP.  Java is the language of choice as the source documents exist on a soon to be retired Solaris server.
The following code works within NASH
<AML>
<ApplyItem>
<Item type='Document' id='76126C1815DA441B80E11492ACF437A4' action='unlock'>
</ApplyItem>
</AML>
But the following does not work within Java.
import java.net.*;
import java.io.*;
import java.security.*;
import java.math.*;
class filecheckin1
    public static String calcMD5(String s) {
        MessageDigest m = null;
        try {
            m=MessageDigest.getInstance("MD5");
            m.update(s.getBytes(),0,s.length());
        catch (NoSuchAlgorithmException e) {
            System.err.println("Invalid algorithm");
            System.exit(-1);
        return (new BigInteger(1,m.digest()).toString(16));
    public static void main(String args[])
    try {
        URL u = new URL("localhost/.../vaultServer.aspx");
        URLConnection uc = u.openConnection();
        HttpURLConnection connection = (HttpURLConnection) uc;
        String boundary = "-------------------------BRdnIy5hBONlyI";
        String docPath = "C:\etihad.pdf";
        connection.setDoOutput(true);
        connection.setRequestMethod("POST");
        connection.setRequestProperty("Content-Type", "multipart/form-data; boundary="+boundary);
        OutputStream os = connection.getOutputStream();
        File file = new File(docPath);
        FileInputStream is = new FileInputStream(file);
        String content = "--"+boundary +" Content-Disposition: form-data; name="SOAPACTION"; Content-Type: text/plain ApplyItem ";
        os.write(content.getBytes());
        content = "--"+boundary +" Content-Disposition: form-data; name="AUTHUSER"; Content-Type: text/plain admin ";
        content = "--"+boundary +" Content-Disposition: form-data; name="AUTHPASSWORD"; Content-Type: text/plain "+calcMD5("innovator")+" ";
        content = "--"+boundary +" Content-Disposition: form-data; name="DATABASE"; Content-Type: text/plain InnovatorSolutions ";
        content = "--"+boundary +" Content-Disposition: form-data; name="XMLDATA"; Content-Type: text/plain ";
        content += "<SOAP-ENV:Envelope xmlns:SOAP-ENV='schemas.xmlsoap.org/.../'>";
        content += " <SOAP-ENV:Body>";
        content += "  <ApplyItem>";
        content += "   <Item type='Document' id='76126C1815DA441B80E11492ACF437A4' action='unlock'>";
        content += "   </Item>";
        content += "  </ApplyItem>";
        content += " </SOAP-ENV:Body>";
        content += "</SOAP-ENV:Envelope> ";
        os.flush();
        os.close();
        InputStream in = connection.getInputStream();
        int c;
        while ((c = in.read()) != -1) System.out.write(c);
        in.close();
    catch (IOException e) {
        System.err.println(e);
Any suggestions on how to unlock an object?
rif6894 - Wednesday, December 14, 2011 5:18 PM:
Appropriate use of  'edit' action allowed the correct lock/unlock functionality
